Any changes on AdguardHome even filter update cause system to hang
is known problem?
AXT1800 4.5
is known problem?
AXT1800 4.5
This often happens if the filter lists are too big - how many lists did you enable?
I think as such, 10 appended to list
Is there easy work around? Down road offload dns another device anyways
yes see problem here
I disable all and only enable one for test and it still hang machine 812m@66%cpu
no see why so much process power require to translate text file
