I have a GL-AR750S. I am getting random reboots and other issues. How do I make sure router is getting correct voltage? What about CPU and memory usage? Is there a way to see this?
If I remember correctly the “Advanced” tap in the Admin Panel - MORE SETTINGS should give you what you’re looking for.
The most common problem is not enough power. Just try another power adapter.
