Client mode with WPA enterprise
I’m trying to connect a GL-AR150 with firmware 2.20 to a WPA Enterprise network. To join the SSID, I just need to put in a username and password, but I do not see WPA Enterprise encryption listed as an option.
I have tried the instructions here, Client Mode Wireless [Old OpenWrt Wiki] but I get 255 errors when installing the wpa-supplicant packages and the network never connects.
Please assist.
OK, I removed hostapd and wpa-supplicant and installed wpad instead. Now I see the options I need to connect, but I am still unable to connect in client mode with all of the fields configured. Any help is appreciated.
the 255 error may not really matter.
Can you post your config? /etc/config/network and /etc/config/wireless
root@GL-AR150:~# vi /etc/config/network
config interface 'loopback'
option ifname 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fd56:6725:xxxx::/48'
config interface 'lan'
option ifname 'eth1'
option force_link '1'
option type 'bridge'
option ip6assign '60'
option hostname 'GL-AR150-1a1'
option ipaddr '192.168.10.1'
config interface 'wan'
option ifname 'eth0'
option proto 'dhcp'
config interface 'wan6'
option proto 'dhcpv6'
config interface 'wwan'
option proto 'dhcp'
root@GL-AR150:~# vi /etc/config/wireless
config wifi-device 'radio0'
option type 'mac80211'
option channel '11'
option path 'platform/ar933x_wmac'
option htmode 'HT20'
option txpower '18'
option disabled '0'
option hwmode '11g'
option country 'US'
config wifi-iface
option network 'wwan'
option ssid 'hostnetworkssid'
option device 'radio0'
option mode 'sta'
option bssid 'F0:B2:E5:xx:xx:xx'
option eap_type 'peap'
option identity 'myusername@domain'
option password 'mypwd'
option encryption 'wpa2+ccmp'
Additionally, the WiFi scan function eventually dies and will not scan for networks unless I factory reset the router.
I got the client mode to work and then realized what I need is an ethernet bridge. so I’ve posted over on the OpenWRT forum here: OpenWrt Forum Archive
I don’t think you need to build a relay on top of EAP wireless network. The enterprise network will automatically deal with this.
