# Clients page weirdness
**URL:** <https://forum.gl-inet.com/t/clients-page-weirdness/14335>\
**Category:** Router\
**Created:** [February 13, 2021, 9:22pm UTC](https://forum.gl-inet.com/t/clients-page-weirdness/14335 "2021-02-13T21:22:02Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![pingpong](https://forum-assets.gl-inet.com/letter_avatar_proxy/v4/letter/p/4bbf92/32.png) [@pingpong](https://forum.gl-inet.com/u/pingpong)\
**Post date:** [February 13, 2021, 9:22pm UTC](https://forum.gl-inet.com/t/clients-page-weirdness/14335/1 "2021-02-13T21:22:02Z")
</div>
I’m noticing some weirdness and inconsistencies on the clients page (Mango GL-MT300N-V2 firmware 3.105 (current)).
1. Only one device has a properly resolved DNS name. All others show an asterisk. Most of these do in fact have DNS PTR records for the IPs listed.
2. One one device has the ‘block’ toggle in dark grey (functional); the rest are very light grey. Coincidentally, this is the same as the one that has the only resolved DNS name.
3. One device in the “2.4G Wireless Device” has the correct MAC address but the IP is completely wrong (and the IP is unpingable).
4. Is there a way to clear entries from this table? Individually would be best. A complete wipe right now would be OK as well.
[Edit: I did what I could do–reboot it–but the entire table stayed put.]
**Author:** ![alzhao](https://forum-assets.gl-inet.com/letter_avatar_proxy/v4/letter/a/5f9b8f/32.png) [@alzhao](https://forum.gl-inet.com/u/alzhao)\
**Post date:** [February 14, 2021, 5:05am UTC](https://forum.gl-inet.com/t/clients-page-weirdness/14335/2 "2021-02-14T05:05:03Z")
</div>
Can you remove the offline clients
> [@How to remove entries in the client list?](https://forum.gl-inet.com/t/how-to-remove-entries-in-the-client-list/9321/7):
> Can anyone advise on how to write this to a script? I am trying to set things up so these commands run on boot, but, for me at least, the ‘service gl\_tertf stop’ command is running into errors when executed through a script. It seems to not understand what ‘service’ is. Edit: Silly me, it’s easier to just add two lines of code to remove the backup files at the beginning of the start\_service() function of /etc/init.d/gl\_tertf.
**Post date:** [February 14, 2021, 3:14pm UTC](https://forum.gl-inet.com/t/clients-page-weirdness/14335/3 "2021-02-14T15:14:21Z")
</div>
@alzhou Thanks for the link to that other thread! That seemed to work to fix item 4 in my list of questions.
For convenience to others, quoted here:
–begin snippet–
Can you just add to /etc/rc.local
```auto
rm /tmp/tertf/tertfinfo_bak
rm /etc/tertf/tertfinfo_bak
–end snippet–
And then I rebooted.
Though comfortable with the CLI, I used the OpenWRT GUI under System → Startup and modified the /etc/rc.local file from there. Worked like a charm.
Future enhancement request: allow removal of individual entries, or a big “clear” button on the GUI to do so.
**Post date:** [February 16, 2021, 9:47am UTC](https://forum.gl-inet.com/t/clients-page-weirdness/14335/4 "2021-02-16T09:47:54Z")
</div>
> [@pingpong](#):
Yes. Definitely will be.
**Author:** ![bruce](https://forum-assets.gl-inet.com/user_avatar/forum.gl-inet.com/bruce/32/35649_2.png) [@bruce](https://forum.gl-inet.com/u/bruce)\
**Post date:** [October 29, 2025, 4:12am UTC](https://forum.gl-inet.com/t/clients-page-weirdness/14335/5 "2025-10-29T04:12:49Z")
</div>
