Collie (GL-X300B-GPS) - SIM card cannot be registered? (4G profile)
Hi all,
When trying to setup a 4G internet we got an error : (i) SIM card cannot be registered. Please check: 1. You are using the compatible modem for your carrier; 2. Whether a specific APN or data plan is reequired.
We are unable to apply carrier settings in “manuel setup” because our carrier provides APN, PAP, and empty username and password but the username and password fields can not be empty when using PAP /CHAP in Collie.
Do you have any idea how I can get around this to have empty user and password fields?
Does anyone else have a similar problem?
Thanks for your help
Hi @alzhao,
May you help for this please ?
BR,
Aldo
I replied your email.
Hi all
I got the same message. @Alzhao, can you help me to solve it, please?
Same problem?
Try 3.215 beta3
@alzhao I’m having the same problem with a GL-X300B running 3.215. AT&T Prepaid SIM doesn’t work, Mint Mobile does but their network around me isn’t very good. I’d prefer to use AT&T.
Pls write email to support at glinet.biz
May need to do remote check.
