Collie (GPS Version) Questions
Hi.
I've just got hold of a Collie ( X300B-GPS) to play with.....
  1. Where is the reset button?
  2. Is it OK to leave the GPS antenna unatteched (I don't intend to use this)?
Thanks in advance.
Happi.
Reset key should be next to the SIM:
Thanks, don't know how I missed that!
It's marked RST if anyone is interested.
  1. Wondering if there is any way to add a USB port to this device (for example through the green data interface)?
  2. Also, can somebody adivse the antennae connector type (GPS version), as I'd like to replace the paddle antennae with upright platic ones, if possible.
PS. still waiting for an answer to Q2 in OP, if anybody has an idea!
