Comet-X unresponsive after a day
I just got my Comet-X with release V1.8.1 on it, but updated to V1.10.1 release4.
It worked fine until today, I noticed that it was not present on the network when I pinged it. It is powered by a Unifi switch via PoE. The port showed an active 1 Gbit/s connection. When I power-cycled the port, the device came up again.
All ports are connected to devices, also a monitor, mouse and keyboard are present.
Are there any newer (or older) firmware releases that might help with this?
Hi, please try this firmware.
That does not work. The downgrade starts, but after around 30% progress, I am lead to the login screen and the installed version is still displayed as V1.10.1 release4.
I tried twice to no avail. I secured the log file bundle, but I suspect a downgrade lock of sorts?
Could you send us the syslog? Also, have you tried using USB-C for power?
I just did via personal message and no, I did not try USB-C. PoE ist the discriminating feature for me and I am sure it works and is also sufficient, the switch is a Unifi Pro HD 24 PoE.
If it happens again, I will look into the timeline for the port, but as I said: It showed connected when the device did not respond to any IP-based traffic.
Just for reference: The provided version is slightly mislabeled and reports back as V1.10.1 release4 when installed, so it is not a downgrade. I will keep monitoring if if stays stable. Otherwise, it works just fine.
