U-Boot 1.1.4 (Fri May 17 09:44:06 2019)
x300b - Honey Bee 2.0DRAM:
sri
Honey Bee 2.0
ath_ddr_initial_config(195): (16bit) ddr2 init
ath_sys_frequency: cpu 650 ddr 597 ahb 216
tap = 0x00000003
Tap (low, high) = (0xa, 0x23)
Tap values = (0x16, 0x16, 0x16, 0x16)
128 MB
Flash Manuf Id 0xef, DeviceId0 0x40, DeviceId1 0x18
flash size 32MB, sector count = 512
Power up PLL with outdiv = 0 then switch to 3
*** Warning *** : PCIe WLAN Module not found !!!
ath_gmac_enet_initialize...
No valid address in Flash. Using fixed address
ath_gmac_enet_initialize: reset mask:c02200
Honey Bee ---->S27 PHY*
S27 reg init
: cfg1 0x800c0000 cfg2 0x7114
eth0: 00:03:7f:09:0b:ad
eth0 up
Honey Bee ----> MAC 1 S27 PHY *
S27 reg init
ATHRS27: resetting s27
ATHRS27: s27 reset done
: cfg1 0x800c0000 cfg2 0x7214
eth1: 00:03:7f:09:0b:ad
eth1 up
eth0, eth1
Qualcomm Atheros SPI NAND Driver, Version 0.1 (c) 2014 Qualcomm Atheros Inc.
MFR:200,DID:177
====== NAND Parameters ======
sc = 0x87ff7690 page = 0x800 block = 0x20000
Setting 0x181162c0 to 0x4b97a100
Hit 'gl' to stop autoboot: 2 1 0 enet1 port3 up
dup 1 speed 1000
-1
Device 0 bad blocks:
07fe0000
Found ART,Checking calibration status...
Device have calibrated,Checking device test status...
Device haven't tested. Please test device in calibration firmware...
Protect off 9F040000 ... 9F04FFFF
Un-Protecting sectors 4..4 in bank 1
Un-Protected 1 sectors
Erasing Flash...Erasing flash...
First 0x4 last 0x4 sector size 0x10000
4
Erased 1 sectors
Writing to Flash... write addr: 40000
done
Protected 1 sectors
Un-Protect Flash Bank # 1
Booting image at: 0x9F060000
Booting image at 9f060000 ...
Image Name: MIPS OpenWrt Linux-4.14.221
Created: 2021-02-15 15:22:37 UTC
Image Type: MIPS Linux Kernel Image (lzma compressed)
Data Size: 1864367 Bytes = 1.8 MB
Load Address: 80060000
Entry Point: 80060000
Verifying Checksum at 0x9f060040 ...OK
Uncompressing Kernel Image ... OK
No initrd
Transferring control to Linux (at address 80060000) ...
Giving linux memsize in bytes, 134217728
Starting kernel ...
[ 0.000000] Linux version 4.14.221 (glinet@ubuntu) (gcc version 7.5.0 (OpenWrt GCC 7.5.0 r11257-5090152ae3)) #0 Mon Feb 15 15:22:37 2021
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU0 revision is: 00019374 (MIPS 24Kc)
[ 0.000000] MIPS: machine is GL.iNet GL-X300B (NOR)
[ 0.000000] SoC: Qualcomm Atheros QCA9533 ver 2 rev 0
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 08000000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] random: get_random_bytes called from start_kernel+0x98/0x494 with crng_init=0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: console=ttyS0,115200n8 rootfstype=squashfs,jffs2
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Writing ErrCtl register=00000000
[ 0.000000] Readback ErrCtl register=00000000
[ 0.000000] Memory: 122404K/131072K available (4419K kernel code, 160K rwdata, 1008K rodata, 1252K init, 218K bss, 8668K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS: 51
[ 0.000000] CPU clock: 650.000 MHz
[ 0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 5880801374 ns
[ 0.000009] sched_clock: 32 bits at 325MHz, resolution 3ns, wraps every 6607641598ns
[ 0.008259] Calibrating delay loop... 432.53 BogoMIPS (lpj=2162688)
[ 0.074874] pid_max: default: 32768 minimum: 301
[ 0.079952] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.086922] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.098707] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.109133] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.115657] pinctrl core: initialized pinctrl subsystem
[ 0.122397] NET: Registered protocol family 16
[ 0.153361] clocksource: Switched to clocksource MIPS
[ 0.159741] NET: Registered protocol family 2
[ 0.165277] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.172631] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.179398] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.186269] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.192439] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.199378] NET: Registered protocol family 1
[ 0.207022] Crashlog allocated RAM at address 0x3f00000
[ 0.213943] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[ 0.225971] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.232116] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.253346] io scheduler noop registered
[ 0.257544] io scheduler deadline registered (default)
[ 0.265143] pinctrl-single 1804002c.pinmux: 576 pins at pa b804002c size 72
[ 0.273177] gpio-export gpio-export: 3 gpio(s) exported
[ 0.279493] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.288505] Serial port to 485 enable,rs485txen_gpio = gpio1
[ 0.294780] console [ttyS0] disabled
[ 0.298580] 18020000.uart: ttyS0 at MMIO 0x18020000 (irq = 9, base_baud = 1562500) is a 16550A
[ 0.307701] console [ttyS0] enabled
[ 0.315267] bootconsole [early0] disabled
[ 0.342209] m25p80 spi0.0: w25q128 (16384 Kbytes)
[ 0.347169] 4 fixed-partitions partitions found on MTD device spi0.0
[ 0.353753] Creating 4 MTD partitions on "spi0.0":
[ 0.358708] 0x000000000000-0x000000040000 : "u-boot"
[ 0.364685] 0x000000040000-0x000000050000 : "u-boot-env"
[ 0.370963] 0x000000050000-0x000000060000 : "art"
[ 0.376651] 0x000000060000-0x000001000000 : "firmware"
[ 0.385349] 2 uimage-fw partitions found on MTD device firmware
[ 0.391472] Creating 2 MTD partitions on "firmware":
[ 0.396656] 0x000000000000-0x0000001d0000 : "kernel"
[ 0.402557] 0x0000001d0000-0x000000fa0000 : "rootfs"
[ 0.408479] mtd: device 5 (rootfs) set to be root filesystem
[ 0.414422] 1 squashfs-split partitions found on MTD device rootfs
[ 0.420820] 0x000000b70000-0x000000fa0000 : "rootfs_data"
[ 0.429557] spi-nand: Giga SPI NAND was found.
[ 0.434219] spi-nand: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 128
[ 0.442134] 1 fixed-partitions partitions found on MTD device spi0.1
[ 0.448716] Creating 1 MTD partitions on "spi0.1":
[ 0.453690] 0x000000000000-0x000008000000 : "nand_ubi"
[ 0.887758] found bad block 7fe0000
[ 0.892106] libphy: Fixed MDIO Bus: probed
[ 1.234467] ag71xx 19000000.eth: Could not connect to PHY device. Deferring probe.
[ 1.913754] libphy: ag71xx_mdio: probed
[ 2.203829] mdio-bus.0:1f: Found an AR934X built-in switch
[ 2.209712] libphy: ar7240sw_mdio: probed
[ 2.270996] ag71xx 1a000000.eth: connected to PHY at fixed-0:00 [uid=00000000, driver=Generic PHY]
[ 2.280938] eth1: Atheros AG71xx at 0xba000000, irq 5, mode: gmii
[ 2.289283] NET: Registered protocol family 10
[ 2.298584] Segment Routing with IPv6
[ 2.302464] NET: Registered protocol family 17
[ 2.307167] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.320568] 8021q: 802.1Q VLAN Support v1.8
[ 2.327138] Reserved instruction in kernel code[#1]:
[ 2.332288] CPU: 0 PID: 1 Comm: swapper Not tainted 4.14.221 #0
[ 2.338400] task: 87c20000 task.stack: 87c1a000
[ 2.343072] $ 0 : 00000000 80710000 c0050000 00000008
[ 2.348474] $ 4 : 87e10480 00000006 00000008 0000000b
[ 2.353877] $ 8 : 00010000 c00636cc c00536cc 00000000
[ 2.359281] $12 : 00000001 07ba1ae7 0000000f c00526cc
[ 2.364683] $16 : 87e10480 00000000 87e10400 0000000f
[ 2.370086] $20 : 80566538 fffffff5 00000001 80710000
[ 2.375489] $24 : c00516cc 80079cec
[ 2.380892] $28 : 87c1a000 87c1bd30 80710000 80232e64
[ 2.386296] Hi : 001145e5
[ 2.389270] Lo : 07ba1ae7
[ 2.392248] epc : 80271150 zlib_deflateInit2+0x94/0x188
[ 2.397837] ra : 80232e64 deflate_comp_init+0x74/0xa4
[ 2.403319] Status: 1000e403 KERNEL EXL IE
[ 2.407639] Cause : 10800028 (ExcCode 0a)
[ 2.411780] PrId : 00019374 (MIPS 24Kc)
[ 2.415827] Modules linked in:
[ 2.418986] Process swapper (pid: 1, threadinfo=87c1a000, task=87c20000, tls=00000000)
[ 2.427152] Stack : 80232e1c 87e10480 00000000 87e10400 ffffffff 8011d66c 805887b4 fffffffe
[ 2.435789] 00000008 00000000 00000402 87e10400 87e10480 802332e8 0000000f 802334e4
[ 2.444426] 80740000 fffffffe 87e10400 805c6000 00000000 8022939c fffffff5 8022914c
[ 2.453064] 87d9ec00 00020000 80740000 805c6000 00000000 0000000f 00000002 8022948c
[ 2.461701] 80564d7c 801451d4 804b9700 804c1818 00000000 805c4ac0 00000000 80740000
[ 2.470338] ...
[ 2.472867] Call Trace:
[ 2.475391] [<80271150>] zlib_deflateInit2+0x94/0x188
[ 2.480614] [<80232e64>] deflate_comp_init+0x74/0xa4
[ 2.485741] [<802332e8>] deflate_init+0x28/0x70
[ 2.490416] [<8022939c>] __crypto_alloc_tfm+0x120/0x1a8
[ 2.495809] [<8022948c>] crypto_alloc_base+0x68/0x12c
[ 2.501046] [<805e7498>] compr_init+0x24/0x80
[ 2.505542] [<805e7524>] ubifs_compressors_init+0x30/0x80
[ 2.511116] [<805e73e8>] ubifs_init+0x64/0xf0
[ 2.515613] [<80060a50>] do_one_initcall+0xd0/0x1a0
[ 2.520658] [<805d7d50>] kernel_init_freeable+0x150/0x210
[ 2.526238] [<804aa3f8>] kernel_init+0x10/0x104
[ 2.530918] [<80065558>] ret_from_kernel_thread+0x14/0x1c
[ 2.536490] Code: 01ea5021 01c84004 01484821 3c09aaaa 246d0006 3529aaab 24630009 00690019
[ 2.546570]
[ 2.548168] ---[ end trace d7adee90a07a7644 ]---
[ 2.563907] Reserved instruction in kernel code[#2]:
[ 2.563912] CPU: 0 PID: 1 Comm: swapper Tainted: G D 4.14.221 #0
[ 2.563916] task: 87c20000 task.stack: 87c1a000
[ 2.563917] $ 0 : 00000000 00000001 c0003fdc 00000001
[ 2.563927] $ 4 : c0003ffc 80719e68 0000000f 0006c80a
[ 2.563938] $ 8 : 30302038 30356336 30303020 00000000
[ 2.563947] $12 : 30303030 ec526e28 0000008d 20383032
[ 2.563957] $16 : 00000061 00000000 80719e48 0000004f
[ 2.563967] $20 : c0003fca 0000004f 80719e38 00000001
[ 2.563977] $24 : 0000000f 00000000
[ 2.563986] $28 : 87c1a000 87c1bb28 00002036 800b1d9c
[ 2.563997] Hi : 0000002c
[ 2.563999] Lo : 70a3d7bc
[ 2.564002] epc : 804a9db0 __copy_user+0x4c/0x2bc
[ 2.564006] ra : 800b1d9c msg_print_text+0xd0/0x130
[ 2.564008] Status: 1000e402 KERNEL EXL
[ 2.564015] Cause : 50808028 (ExcCode 0a)
[ 2.564018] PrId : 00019374 (MIPS 24Kc)
[ 2.564020] Modules linked in:
[ 2.564026] Process swapper (pid: 1, threadinfo=87c1a000, task=87c20000, tls=00000000)
[ 2.564028] Stack : 09ffffff 000affff 804e0000 804e1d2c 8073a290 00000000 00001faa 805c0000
[ 2.564044] 0000007a 00000000 00000000 000020a0 00000000 800b23d4 80730000 00000001
[ 2.564061] 00000001 804a8ba0 00003fe0 00000001 c0002020 00000001 80740000 8055a094
[ 2.564077] 805c0000 805c0000 8073a290 80730000 80730000 00000001 00000001 800fd48c
[ 2.564093] 0000000b 805c20d8 00000000 87c1bbac 87c1bbc4 fffffff5 00000001 800b3c34
[ 2.564110] ...
[ 2.564115] Call Trace:
[ 2.564118] [<804a9db0>] __copy_user+0x4c/0x2bc
[ 2.564121] [<800b1d9c>] msg_print_text+0xd0/0x130
[ 2.564125] [<800b23d4>] kmsg_dump_get_buffer+0x22c/0x318
[ 2.564128] [<800fd48c>] crashlog_do_dump+0xfc/0x130
[ 2.564131] [<800b470c>] kmsg_dump+0xf0/0x138
[ 2.564134] [<8006acd0>] die+0xbc/0xfc
[ 2.564136] [<8006b98c>] do_ri+0xb8/0x394
[ 2.564140] [<800663e0>] handle_ri_int+0x28/0x48
[ 2.564143] [<80232e64>] deflate_comp_init+0x74/0xa4
[ 2.564145] Code: 8cac0010 8caf0014 ac880000 8ca80018 8ca9001c 24a50020 24840020 ac8affe8
[ 2.564164]
[ 2.564167] ---[ end trace d7adee90a07a7645 ]---
[ 2.564170] Reserved instruction in kernel code[#3]:
[ 2.564175] CPU: 0 PID: 1 Comm: swapper Tainted: G D 4.14.221 #0
[ 2.564178] task: 87c20000 task.stack: 87c1a000
[ 2.564180] $ 0 : 00000000 00000001 c0004000 00000001
[ 2.564190] $ 4 : c0004000 80555993 00000000 804c67e4
[ 2.564199] $ 8 : 0000003e 00000000 00000001 00000000
[ 2.564209] $12 : 66666666 13b19260 00000000 00000000
[ 2.564219] $16 : c0004000 80555993 87c1b90c 80555994
[ 2.564229] $20 : 00000001 ffffffff 804e1d0c 3fffc001
[ 2.564238] $24 : 00000004 00000000
[ 2.564248] $28 : 87c1a000 87c1b888 c0003ffe 804a8700
[ 2.564259] Hi : 00000000
[ 2.564261] Lo : 00000000
[ 2.564264] epc : 804a9f30 __copy_user+0x1cc/0x2bc
[ 2.564267] ra : 804a8700 vsnprintf+0xc8/0x554
[ 2.564269] Status: 1000e402 KERNEL EXL
[ 2.564277] Cause : 90800028 (ExcCode 0a)
[ 2.564280] PrId : 00019374 (MIPS 24Kc)
[ 2.564282] Modules linked in:
[ 2.564288] Process swapper (pid: 1, threadinfo=87c1a000, task=87c20000, tls=00000000)
[ 2.564290] Stack : 80555994 e9938325 804e0000 ffffffff 0fffffff 000affff 804e0000 804e1d2c
[ 2.564306] 805d0000 80588b18 00ffffff 000affff 00000004 c0003ffe 80719e38 0000004f
[ 2.564322] c0003ffe 0000004f 80719e38 00000001 00002002 804a8c7c 804e1d0c e9938325
[ 2.564339] c000204d 8055a082 87c1b9ac 87c1b908 00000003 800b1ad8 804e1d0c c0002053
[ 2.564355] 00000004 804c67e2 00000000 00000000 80719e48 800b1d84 09ffffff 000affff
[ 2.564371] ...
[ 2.564376] Call Trace:
[ 2.564379] [<804a9f30>] __copy_user+0x1cc/0x2bc
[ 2.564382] [<804a8700>] vsnprintf+0xc8/0x554
[ 2.564385] [<804a8c7c>] sprintf+0x2c/0x38
[ 2.564388] [<800b1ad8>] print_prefix+0x48/0x23c
[ 2.564391] [<800b1d84>] msg_print_text+0xb8/0x130
[ 2.564395] [<800b23d4>] kmsg_dump_get_buffer+0x22c/0x318
[ 2.564398] [<800fd48c>] crashlog_do_dump+0xfc/0x130
[ 2.564401] [<800b470c>] kmsg_dump+0xf0/0x138
[ 2.564404] [<8006acd0>] die+0xbc/0xfc
[ 2.564407] [<8006b98c>] do_ri+0xb8/0x394
[ 2.564410] [<800663e0>] handle_ri_int+0x28/0x48
[ 2.564413] [<800b1d9c>] msg_print_text+0xd0/0x130
[ 2.564417] [<800b23d4>] kmsg_dump_get_buffer+0x22c/0x318
[ 2.564420] [<800fd48c>] crashlog_do_dump+0xfc/0x130
[ 2.564423] [<800b470c>] kmsg_dump+0xf0/0x138
[ 2.564426] [<8006acd0>] die+0xbc/0xfc
[ 2.564429] [<8006b98c>] do_ri+0xb8/0x394
[ 2.564432] [<800663e0>] handle_ri_int+0x28/0x48
[ 2.564435] [<80232e64>] deflate_comp_init+0x74/0xa4
[ 2.564438] Code: 00000000 80a80000 24c6ffff <10c00009> a0880000 80a80001 24c6ffff 10c00005 a0880001
[ 2.564456]
[ 2.564459] ---[ end trace d7adee90a07a7646 ]---
[ 2.564463] Reserved instruction in kernel code[#4]:
[ 2.564467] CPU: 0 PID: 1 Comm: swapper Tainted: G D 4.14.221 #0
[ 2.564470] task: 87c20000 task.stack: 87c1a000
[ 2.564472] $ 0 : 00000000 00000001 c0003fe2 00000001
[ 2.564482] $ 4 : c0003ff4 80719e0a 0000002d 0006a64d
[ 2.564492] $ 8 : 30303030 30303020 30303030 00000000
[ 2.564502] $12 : 66666666 d89e622b 00000000 00000000
[ 2.564512] $16 : 00000061 00000000 80719de8 0000004f
[ 2.564521] $20 : c0003fd0 0000004f 80719dd8 00000001
[ 2.564531] $24 : 0000000d 00000000
[ 2.564541] $28 : 87c1a000 87c1b680 00002030 800b1d9c
[ 2.564552] Hi : 0000002b
[ 2.564554] Lo : 91eb85cd
[ 2.564557] epc : 804a9ee0 __copy_user+0x17c/0x2bc
[ 2.564561] ra : 800b1d9c msg_print_text+0xd0/0x130
[ 2.564563] Status: 1000e402 KERNEL EXL
[ 2.564570] Cause : 10800028 (ExcCode 0a)
[ 2.564573] PrId : 00019374 (MIPS 24Kc)
[ 2.564575] Modules linked in:
[ 2.564582] Process swapper (pid: 1, threadinfo=87c1a000, task=87c20000, tls=00000000)
[ 2.564583] Stack : 09ffffff 000affff 804e0000 804e1d2c 8073a290 00000000 00001f48 805c0000
[ 2.564600] 00000079 00000000 00000000 00002040 00000000 800b23d4 80730000 00000001
[ 2.564616] 00000001 804a8ba0 00003f78 00000001 c0002088 00000001 80740000 00000002
[ 2.564633] 805c0000 80730000 8073a290 80730000 80730000 00000001 00000001 800fd48c
[ 2.564649] 0000100a 00000002 00084607 dc31e92b 87c1b71c 804a8700 00000001 0000100a
[ 2.564665] ...
[ 2.564671] Call Trace:
[ 2.564674] [<804a9ee0>] __copy_user+0x17c/0x2bc
[ 2.564677] [<800b1d9c>] msg_print_text+0xd0/0x130
[ 2.564680] [<800b23d4>] kmsg_dump_get_buffer+0x22c/0x318
[ 2.564684] [<800fd48c>] crashlog_do_dump+0xfc/0x130
[ 2.564687] [<800b470c>] kmsg_dump+0xf0/0x138
[ 2.564689] [<8006acd0>] die+0xbc/0xfc
[ 2.564692] [<8006b98c>] do_ri+0xb8/0x394
[ 2.564695] [<800663e0>] handle_ri_int+0x28/0x48
[ 2.564698] [<804a8700>] vsnprintf+0xc8/0x554
[ 2.564701] [<804a8c7c>] sprintf+0x2c/0x38
[ 2.564704] [<800b1ad8>] print_prefix+0x48/0x23c
[ 2.564707] [<800b1d84>] msg_print_text+0xb8/0x130
[ 2.564711] [<800b23d4>] kmsg_dump_get_buffer+0x22c/0x318
[ 2.564714] [<800fd48c>] crashlog_do_dump+0xfc/0x130
[ 2.564717] [<800b470c>] kmsg_dump+0xf0/0x138
[ 2.564720] [<8006acd0>] die+0xbc/0xfc
[ 2.564722] [<8006b98c>] do_ri+0xb8/0x394
[ 2.564725] [<800663e0>] handle_ri_int+0x28/0x48
[ 2.564729] [<800b1d9c>] msg_print_text+0xd0/0x130
[ 2.564732] [<800b23d4>] kmsg_dump_get_buffer+0x22c/0x318
[ 2.564735] [<800fd48c>] crashlog_do_dump+0xfc/0x130
[ 2.564738] [<800b470c>] kmsg_dump+0xf0/0x138
[ 2.564741] [<8006acd0>] die+0xbc/0xfc
[ 2.564744] [<8006b98c>] do_ri+0xb8/0x394
[ 2.564747] [<800663e0>] handle_ri_int+0x28/0x48
[ 2.564750] [<80232e64>] deflate_comp_init+0x74/0xa4
[ 2.564753] Code: ac880000 ac890004 ac8a0008 24840010 14d8fff0 00000000 10c00019 30d80003
[ 2.564771]
[ 2.564774] ---[ end trace d7adee90a07a7647 ]---
[ 2.564778] Reserved instruction in kernel code[#5]:
[ 2.564782] CPU: 0 PID: 1 Comm: swapper Tainted: G D 4.14.221 #0
[ 2.564786] task: 87c20000 task.stack: 87c1a000
[ 2.564787] $ 0 : 00000000 00000001 c0003fb4 00000001
[ 2.564797] $ 4 : c0004000 80719dd4 00000003 00068490
[ 2.564807] $ 8 : 00666665 c0004003 00000008 00000000
[ 2.564817] $12 : 66666666 ec502309 00000000 20383031
[ 2.564826] $16 : 00000061 00000000 80719d88 0000004f
[ 2.564836] $20 : c0003fa2 0000004f 80719d78 00000001
[ 2.564846] $24 : 00000018 00000000
[ 2.564856] $28 : 87c1a000 87c1b478 0000205e 800b1d9c
[ 2.564867] Hi : 0000002a
[ 2.564869] Lo : b5c29007
[ 2.564872] epc : 804a9e68 __copy_user+0x104/0x2bc
[ 2.564875] ra : 800b1d9c msg_print_text+0xd0/0x130
[ 2.564877] Status: 1000e402 KERNEL EXL
[ 2.564885] Cause : 10800028 (ExcCode 0a)
[ 2.564888] PrId : 00019374 (MIPS 24Kc)
[ 2.564890] Modules linked in:
[ 2.564897] Process swapper (pid: 1, threadinfo=87c1a000, task=87c20000, tls=00000000)
[ 2.564898] Stack : 09ffffff 000affff 804e0000 804e1d2c 8073a290 00000000 00001ee6 805c0000
[ 2.564915] 00000078 00000000 00000000 00001fe0 00000000 800b23d4 80730000 00000001
[ 2.564931] 00000001 804a8ba0 00003f44 00000001 c00020bc 00000001 80740000 00000002
[ 2.564947] 805c0000 80730000 8073a290 80730000 80730000 00000001 00000001 800fd48c
[ 2.564964] 000019d6 00000002 00084b61 efe3aa09 87c1b514 800b1d9c c0003fd0 000019d6
[ 2.564980] ...
[ 2.564985] Call Trace:
[ 2.564988] [<804a9e68>] __copy_user+0x104/0x2bc
[ 2.564992] [<800b1d9c>] msg_print_text+0xd0/0x130
[ 2.564995] [<800b23d4>] kmsg_dump_get_buffer+0
[ 2.565000] Lost 983 message(s)!
