I’m triying to compile the firmware for the MIFI router but I’m stuck at the copy file step .
I Use this manual :
the procedure states to copy 2 files :
I need to copy some files to OpenWrt tree, including default
configurations (“files”), software packages (“dl”) and Domino
cp files to openwrt-mifi/ -r
cp dl to openwrt-mifi/ -r
I can not find those 2 files anywhere on the git hub repo .
could you indicate me where i could find those files in order to load the default config file for the mifi router .
would this also include the EU 4G modem drivers ?
Best Regards
maybe you can just omit those files as they re not really needed for a working firmware. It just contains some opensource UI.
Just use the code from git hub: GitHub - domino-team/openwrt-cc: openwrt CC with Domino/GL patches
in ‘make menuconfig’ select GL-MiFi as the target, and select LuCi so that you have web interface.
<span style=“color: #eb4b00; font-family: source_sans_proregular, ‘Helvetica Neue’, Arial, Helvetica, Geneva, sans-serif; font-weight: bold; line-height: 22px; background-color: #f9f9f9;”>alzhao,</span>
thx for your Answer .
and for the <span style=“color: #222222; font-family: source_sans_proregular, ‘Helvetica Neue’, Arial, Helvetica, Geneva, sans-serif; font-size: 14px; line-height: 22px;”>EU 4G modem support, what should i add?
Regards</span>
