Hello GL-inet Team,
the plugin „stunnel“ is not working on the B1300.
Can you compile it for?
Many thanks in advance
best regards
Hello GL-inet Team,
best regards
Can someone help to compile the newest stunnel (5.56) for the B1300 ( IPQ40xx) - Is that possible?
Best regards
Since the B1300 uses qsdk and the version is 15.05, I am not sure if it is ok. We will look at this internally and reply to you later. Thank you.
Thank you in advance for your efforts
"root@GL-B1300:~# stunnel
/usr/bin/stunnel: symbol 'COMP_zlib': can't resolve symbol"
The actual issue is the factory default libopenssl package is compiled without “compression support” enable.
So I upload a enabled version for you.
Also you prefered new version of stunnel package and openwrt package source.
https://drive.google.com/drive/folders/1yTxN0otpGCrDTSh_EUyYP3MxAOsHZksV?usp=sharing
Hello hansome, you are awesome!!! <3
It works perfect.
Iam happy now
best regards
