Hello any can tell where i can find this menu.
i can’t find at when make menuconfig
gl-inet–> [*] gl-inet
i try build from :
git clone git://git.openwrt.org/15.05/openwrt.git
any basic tutorial to build what need to be choose
i try build from :
Only for GL.inet 6416
download the attachment, unzip it and put in your openwrt/packages/
in your menuconfig select
gl-inet > [*] gl-inet-compiled
Actually is the the webUI and all configurations of the GL stock firmware. You don’t need this if you compile your own firmware. Just choose packages you need and you can use Luci.
