Configure Flint 2
Hello, I'm contacting you for help. I need to configure Flint 2 for TIM FTTH. TIM provides these parameters. USERNAME: phone_number PASSWORD: timadsl PROTOCOL: PPPoE Routed (defined as RFC 2516) ENCAPSULATION: VLAN Ethernet 802.1q NAT: active VLAN: 835 IGMP proxy: disabled Routing: unicast traffic I'm wondering where they should be inserted. I also need to configure the 2.4GHz and 5GHz Wi-Fi split and automatic software updates. Can you help me? Thanks.
ps also I don't want to use WireGuard or OpenVPN but use my ISP's protection. What should I do?
Please refer to the following documentation to configure the WAN port to PPPoE mode and then enter the corresponding account/password/VLAN ID should be able to connect Flint 2 to the internet.
Ethernet - GL.iNet Router Docs 4
By default, the 2.4GHz and 5GHz Wi-Fi bands already have separate SSIDs if this's what you mentioned as Wi-Fi split.
We do not support automatic firmware updates.
However, when you access the Admin Panel, it will prompt you to update if a new firmware version is available.
Yes, and the “ignore this update” function does not work because the message is displayed again every time the panel is opened.
This is a bug present in certain versions, which we have fixed in the newly released version.
May we know what model and firmware version that you meet this bug?
