Good morning,
How can I configure VLANs on the GL-AX1800 (Flint) router? My intention is to create one VLAN for ports 1 and 2 and another for ports 3 and 4.
Is this possible? Will this be implemented in the future?
There are plenty of threads inside our forum that might help you. The VLAN configuration is not supported by the GL GUI so you will need to utilize luci or SSH.
See https://openwrt.org/docs/guide-user/network/vlan/switch_configuration
