Connect GL-MT3000 to Vodafone broadband
Here is my nslookup from PC terminal. Does not look good. Works ok from LUCI.
C:\Users\muggi>nslookup google.com
DNS request timed out.
timeout was 2 seconds.
Server: UnKnown
Address: 10.0.0.1
Non-authoritative answer:
Addresses: 2a00:1450:4009:827::200e
142.250.200.46
Check that the Router IP address matches the DNS Servers address on your PC.
If your router IP address is 192.168.1.1
Then in the outout of ipconfig /all you should see
DNS Servers . . . . . . . . . . . : 192.168.1.1
They do match.. Prior to my recent move to Vodafone my Beryl router was attached to a Virgin router in modem mode. It all worked fine. I have no clue what is going on now but I think a factory reset is imminent.
One factory reset later and things are looking a lot better. I have no idea what has caused this mess.
More woes.. Factory reset seemed to fix this, but I restored all my settings, samba, fixed ips, tailscale, adguard, etc and problems returned. It seems Adguard is the culprit. It never caused issues before. Does it get upgraded?
