Hello.
I have a problem.
I have 2 devices:
GL-MT1300 / Beryl and GL-E750 / Mudi.
I need to implement this scheme: Mudi with sim-card makes wi-fi with TOR
Then the second device: Beryl should connect to this WIFI and create a new one WIFI with TOR.
But for some reason Beryl after connecting to Mudi’s wifi - not working (no internet)…
Please help me.
You want double Tor?
Does Mudi connect to Tor succesfully?
One thing: you need to change IP address of either one from 192.168.8.1 to others e.g. 192.168.10.1
Yes. I need double TOR (tor on each device).
Mudi connect to TOR perfect.
But then Beryl connects (via WIFI) to Mudi - no internet on Beryl…
I have already changed IP address of Beryl to 192.168.10.1… but it not helps.
I have tried to connect Beryl to another WIFI (not mudi, without tor) - Beryl works great.
But something problem then I’m trying to connect to the MUDI wifi with tor.
Also in Beryl i have a problem - i cant change Timezone. It always shows 6 sep 2020. But in my system set up another time…
Maybe double Tor does not work.
I will check the timezone problem.
Same time zone problem as my thread is there a soulution.
I read another time zone withe the presisitant SSID I have the same issue with your products
