Connect to VPN device from outside
Hey there,
I think I have a wall in my head and I did not find the solution
I have a office (Point A) and Home (Point B) Router
Point A have a double NAT and I have no chance to connect from outside
Point B Had a static IP Adress with Tailscale on it
Device A Is a Unraid Server with Tailscale IP 1.2.3.4 → Port 5678
Now my problem is, I want to connect to the Device A from outside over my static IP Adress from Point B but I didn’t receive a ping from outside
When I use the CLI from Point B and Ping Device A I have a ping
I think the routes are wrong or not there
Anyone have an idea how can I realize that ?
What is the outside device? What operating system?
Lets name the outside device C
You should add a route to C firstly
1.2.3.0/24 via 1.2.3.4 dev xxx
Then add forwarding rules for wan to tailscale in Point B.
Another easier way is to install tailscale in C and add it to the tailscale group of A and B.
Hey
I have done It with a small VPS and NGINX. It was easier and a bit faster :smiley:
Thanks so much for your answer :smile:
Nico
