Hello, I am new here and GL-MT3000 IS my first router from GL.iNet. I set it up behind my ISP router via LAN within the same network. The problem is that I'm getting a "No Internet Connection! Find a network to reconnect" message, please check your network and try again."
Make sure are connecting from LAN on your ISP router to the WAN port on the Beryl AX
Yes my connection are right
ISP lan cable connected to WAN port on GL.inet router and I’m still getting the same response
Please make sure you are using the original power supply. 5V/3A.
Please provide a screenshot of the 'INTERNET' page to check whether the Ethernet IP address has been obtained.
