Connecting to through different clients connected to one host
Hello.
I have a VPN server setup via my GLI router at home with permanent connection to an offsite server connected via a GLI router. When I am physically in my home lasn I can connect to the remote server without any issues. However, when I try connect offsite, eg. I am on a laptop on vacation and need to access that remote server, I am unable to do so. I've tried via fireguard on my laptop and trying to use another client router.
Can't ping it. Can't connect or see it at all.
I'm guessing there are some sort of routing rules that need to be configured? Any help here?
Diagram attached.
Why are there 2 VPN Server?
Does the VPN server (router WAN port) have public IP?
Here for your reference to build the Home WireGuard VPN server:
Oops. My diagram had a pretty important typo. See updates visual:
My VPN server is working but each client node can only talk the objects in my home network.
Example above, if I'm connected from my remotely from laptop laptop, I can talk to my home server and vice versa. However, I can't talk a remote server I have connected VIA VPN from my laptop.
I can't get objects connecting in via VPN to talk to each other.
Thanks, @bruce
