Could TWO opal work under a brume now?
hi,
my brume is 192.168.8.1
the opals are set into 192.168.58.1, and 192.168.59.1 , in router mode.
(they of cause have a 192.168.8.x IP)
i have bought one SF1200 to prevent 2 opal to work together,
but that SF1200 got abandoned, by the company.
thank you.
Can you please specify your question?
I am not totally sure what the question is.
All routers should work fine with whatever other routers used.
that will be good then, thanks.
it's just the CS from taobao told me that better dont use 2 opal inside the same LAN.
let's put that aside then thx
You need to configure each Opal, so the networks don't overlap — but should be fine then.
But I wouldn't recommend the Opal. It's not powerful enough and feels like an EOL product already.
