I have ethernet only security cameras and my wifi modem (E5577) has no ethernet port. I need to create an ethernet access point.
I have Creta and would like to connect to my wifi modem via wi fi to then be able to connect my ethernet only security cameras to ethernet port on Creta.
Wifi modem-> Creta-> security camera
(No ethernet port) (ethernet cable)
Im thinking i need to set up creta to connect to my wifi then change the details of creta to same as my wifi so the cameras think its connected to my wifi modem via ethernet cable…? First time set up and I am unsure on what to do.
You can connect Create to your Modem using Repeater. Then, after connecting the camera to Creta using a Ethernet cable, turn on DMZ on Creta and select the LAN IP of your camera.
The client connected to your Modem will then be able to access your camera via the WAN IP of the Creta.
