Custom DDNS & bug
Hey GL iNet Team,
Thank you for your support and your products.
Im already waiting for the next flint2 firmware and i really hope that you will give us the Feature to change the ddns so a custom one and not force us to use the glddns. It wouldnt be a problem if u could use subdomains like lets say if u have a jellyfin server "jelly.xxxxx.glddns.com". I think a lot of people out their want to use custom ones without messing around in luci. So please...
It would also nice to have more newer Version of openwrt with stock firmware but that was said many times already. :slight_smile:
So far im happy with my flint 2. Runs good.
I also have a Bug to report when using android glinet app. When u want to change a Client icon in the App, i only get the Error: "Status code:500".
Greetings from germany.
Thank you for your post and advice.
We are aware this issue, and improved, next firmware will resolve it.
We are considering adding more DDNS service providers, but it may not support to add the subdomains.
If you need a subdomain, you may need to install the Luci plugins.
Hey Bruce,
Isnt the subdomain a Feature of the custom ddns Provider? Would be great to have the chance to use custom ones like in the fritz boxes. Many germans who buy your stuff come from avm fritzbox to get more Features. If u could manage to close this gab it would be awesome.
Which plugins do i have to install to get custom ddns with subdomains working ?
Yes, on the one hand, the third-party DDNS provider should be supported the subdomain names, and on the other hand, the it requires to the third-party DDNS plug-in in the Luci and the parameters corresponding to the DDNS provider are configured.
There is an universal DDNS plugin:
opkg update
opkg install ddns-scripts luci-app-ddns
Or install on the Luci > System > Software > update list > scan the plugin:
ddns-scripts
luci-app-ddns
If the corresponding DDNS provider has a dedicated plugin, you can ask whether it supports op21 or op24 of aarch64_cortex-a53 (Flint 2 firmware info).
