I was previously using a custom EDID (for 2340x1080 resolution) with firmware 1.2.3. This worked fine. Since upgrading to 1.3.0 if I use the same EDID then it sees it as a 2560x1440 resolution. This means that I get permanent black bars at the top and bottom of the image which is what I was trying to avoid. This is the EDID code I am using (that worked perfectly before the upgrade):
02 03 18 40 23 09 06 07 67 03 0c 00 00 00 10 22
67 d8 5d c4 01 22 80 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 bf
