Hi everyone…
I have a GL iNet x750 router and just wondering if anyone knows should it have in the firewall a custom rule already written see below
What is this for? Should I remove it?
Any advice very welcome
Thanks
legepe
force_dns() {
# lanip=$(ifconfig br-lan |sed -n ‘s/.dr:(.) Bc.*/\1/p’)
lanip=$(uci get network.lan.ipaddr)
tor=$(ps|grep /usr/sbin/tor|grep -v grep)
[ “$1” = “add” ] && {
ip=$(uci get glconfig.general.ipaddr)
[ -z “$ip” ] && ip=$(uci get network.lan.ipaddr)
iptables -t nat -D PREROUTING -i br-+ -s 0/0 -p udp --dport 53 -j DNAT --to $ip
iptables -t nat -D PREROUTING -i br-+ -s 0/0 -p tcp --dport 53 -j DNAT --to $ip
uci set glconfig.general.ipaddr=$lanip
uci commit glconfig
iptables -t nat -C PREROUTING -i br-+ -s 0/0 -p udp --dport 53 -j DNAT --to $lanip
[ ! "$?" = "0" ] && iptables -t nat -I PREROUTING -i br-+ -s 0/0 -p udp --dport 53 -j DNAT --to $lanip
iptables -t nat -C PREROUTING -i br-+ -s 0/0 -p tcp --dport 53 -j DNAT --to $lanip
[ ! "$?" = "0" ] && iptables -t nat -I PREROUTING -i br-+ -s 0/0 -p tcp --dport 53 -j DNAT --to $lanip
if [ -n "$tor" ];then
iptables -t nat -C PREROUTING -i br-lan -p tcp -m tcp --dport 53 -j REDIRECT --to-ports 9053
[ ! "$?" = "0" ] && iptables -t nat -I PREROUTING -i br-lan -p tcp -m tcp --dport 53 -j REDIRECT --to-ports 9053
iptables -t nat -C PREROUTING -i br-lan -p udp -m udp --dport 53 -j REDIRECT --to-ports 9053
[ ! "$?" = "0" ] && iptables -t nat -I PREROUTING -i br-lan -p udp -m udp --dport 53 -j REDIRECT --to-ports 9053
fi
[ "$1" = "remove" ] && {
lanip=$(uci get glconfig.general.ipaddr)
[ -z "$lanip" ] && lanip=$(uci get network.lan.ipaddr)
[ "$?" = "0" ] && iptables -t nat -D PREROUTING -i br-+ -s 0/0 -p udp --dport 53 -j DNAT --to $lanip
[ "$?" = "0" ] && iptables -t nat -D PREROUTING -i br-+ -s 0/0 -p tcp --dport 53 -j DNAT --to $lanip
iptables -t nat -D PREROUTING -i br-lan -p tcp -m tcp --dport 53 -j REDIRECT --to-ports 9053
iptables -t nat -D PREROUTING -i br-lan -p udp -m udp --dport 53 -j REDIRECT --to-ports 9053
fi
force=$(uci get glconfig.general.force_dns)
if [ -n “$force” ]; then
force_dns add
else
force_dns remove
fi
gl-firewall
PPTP Passthrough
iptables -t raw -D OUTPUT -p tcp -m tcp --dport 1723 -j CT --helper pptp
iptables -t raw -A OUTPUT -p tcp -m tcp --dport 1723 -j CT --helper pptp
