Hi, what is the easiest way to customise the UI? I want to remove/disable the OpenVPN client configuration page.
I will enable and force OpenVPN autologin profile login (via CLI) and disable the SSH login after that.
You can modify files in /usr/share/glweb and edit the files.
Thanks for the fast response.
