Customizing Admin Panel
Is there a way to add an menu item on the left hand side menu? I like to add an item such as “My App” to point to an URL like “http://192.168.8.1/cgi-bin/myapp
If you are familiar with JavaScript, you can write <script> to append to the /www/gl_home.html page.
This is a reference, on our Chinese forum
Thanks. It works great. Now if I’m going to write a shell script to patch the /www/gl_home.html, how do I determine the version of the official Admin panel so I can apply the correct patch?
You can send http request by curl.
curl -k http://127.0.0.1/rpc -d "{\"jsonrpc\":\"2.0\",\"method\":\"call\",\"params\":[\"\",\"ui\",\"check_initialized\",{}],\"id\":1}"
The result.firmware_version is the version in The Response.
This is perfect. Thanks.
