Hi, CVE-2026-98432 is a remote use-after-free in the IPv4 TCP handshake code, affecting kernels from 4.4 on. Upstream fixed it in 6.12.113, 6.6.159, 6.1.190, 5.15.223 and 5.10.272, with no fix for 5.4, which is end of life.
Flint 2 stock 4.11.0 runs kernel 5.4.238. Has GL.iNet backported the fix (net/ipv4: "free inet_opt and ireq_opt after an RCU grace period", upstream e3f33b0a1d89)? If not, is a fixed release planned?
Which kernel does 4.11.0-op25-beta1 ship? OpenWrt 25.12.6 is on 6.12.112, one release short of the fix.
To be clear, the exploit allows anybody on the internet to execute remote code on all GL-iNet routers, by sending a specially crafted TCP packet to your public internet IP. Anthropic claims to have exploitation code which performs the RCE, but will obviously not release it publicly, so we have some time until some hacking group with their own AI makes an RCE exploit for it.
The severity rating is Critical 9.8 / 10, and it was patched in Kernel 6.12.113 which came out on October 15th.
It will be fixed in the next OpenWrt version which is coming very soon:
So GL-iNet has to update very quicky when it's out and not drag their feet.
As for all the old GL-iNet devices on the old so-called "stable" firmwares with kernels from 2019, and ancient OpenWrt versions? Just... nuke them and install OpenWrt 25 on them.
Hey, maybe this will be the final motivation to actually update all routers to OpenWrt 25 officially and keep up-to-date with the OpenWrt project and its security patches? This is about more than just the kernel. There's constant exploits being fixed in the OpenWrt code and plugins.
While waiting, I just SSH'd into the router to disable MPTCP support, which is the portion of the exploit that's used for remote code execution. We also have to ensure that socket migration is disabled, which is also used for exploiting. The "-w" command writes the new value and the others check it.
This applies the change to the kernel live, and is not persistent between router reboots. I never reboot and I know the OpenWrt 25 update is out very soon, and then we'll see how fast GL-iNet updates their op25 firmware to include the fix.
PS: I know some people tried to make it persistent, but it's harder than you think (all OpenWrt routers wipe all changes to all disk paths except /etc/config and certain paths marked as "backup during upgrades"). So I won't bother with persistence. Nor will I bother with IP tables rules taht some people have attempted, since people have had issues with those.
Thanks for raising this, and thanks @hashier for the corrections.
By default, the firewall blocks unsolicited inbound WAN connections to the router’s TCP services. Exposure still depends on your configuration, including WAN access permissions, LAN/VPN access and custom firewall rules.
Disabling MPTCP can reduce exposure to the demonstrated exploit, but MPTCP is not required for this vulnerability, and disabling it does not make an affected kernel safe.
Record the current values before changing them, then run over SSH:
sysctl -w net.mptcp.enabled=0
if [ -e /proc/sys/net/ipv4/tcp_migrate_req ]; then
sysctl -w net.ipv4.tcp_migrate_req=0
fi
The conditional skips tcp_migrate_req where it is unavailable, including the stock 5.4 kernel discussed here.
To apply these settings at startup, add the block above to /etc/rc.localbefore the final exit 0, preserving its existing contents. Verify that sysctl net.mptcp.enabled reports 0. Restart services already using MPTCP; services starting before rc.local may also need restarting after boot.
To undo these changes, remove the added block and restore the original values. Correction: The previous instruction to set tcp_migrate_req=1 was incorrect. Its upstream default is 0. If you changed it from 0 to 1 following that instruction, set it back to 0.
These settings are temporary precautions, not a kernel fix. The Red Hat bulletin also describes an IPv4-options filtering mitigation and its limitations.
We are working on the kernel fix, and stock OP21 firmware will also receive the fix.
Thanks @will.qiu for the quick answer, and good to hear a fix is in progress. Will it cover the stock OP21 firmware (4.11.x, kernel 5.4), and not just OP25?
The interim mitigation Red Hat documents is an nftables rule that drops incoming TCP packets carrying IP options (ip protocol tcp ip hdrlength > 5 drop on the input hook, priority -310). Could GL.iNet confirm whether that rule is safe to use on the stock firmware alongside the GL firewall?
Two small things for anyone on stock 4.11.x: net.ipv4.tcp_migrate_req doesn't exist on the 5.4 kernel, so that sysctl just errors. On kernels that do have it, the default is 0, so the undo step sysctl -w net.ipv4.tcp_migrate_req=1 turns on something that was off before, instead of undoing anything.
@hashier What I read is that the TCP migration triggers a race condition, but that MPTCP is necessary for remote code execution.
There's also some (sparse) details here by the discoverers (Anthropic Claude AI):
According to them, the exploit took ~1 hour of targeted attacks until they got root access. And the exploit only works if the router has internet-facing ports (either its own or opened firewall ports that redirect to your computer).
So if you want an easy way to secure it, don't open any ports in the router yet. But since the attack is so slow, I think the risk that you will get rooted is low anyway even if you open ports.
And regarding the mitigation firewall rules: I saw so many variants of different rules + users saying it broke something, so I don't want to go down that path personally. But in theory, the rule that filters out all TCP packets with large headers is a good rule.
GL-iNet have posted an update in another thread, that they will do some patching of their own to fix the exploit soon. Even without waiting for the next OpenWrt release. I am happy to hear this!
Yes—both Opal (GL-SFT1200) and Creta (GL-AR750) are affected on unpatched firmware.
For Opal, firmware 4.8.3 Beta1 includes the fix and is now available from the official beta download page. Please back up your configuration before upgrading, and note that this is a beta release.
Creta has reached end of life, and its official support ended on March 27, 2025. If you plan to keep using it, consider migrating to a maintained upstream OpenWrt build for GL-AR750 that includes this fix—especially if TCP services on the router itself are accessible from the Internet or from untrusted LAN/VPN clients. Upstream OpenWrt replaces the GL.iNet firmware and interface, and support is community-based.
