I’m a very noob in network.
I have a gl-ar750 router.
I want to create new another LAN with another range IP (Exemple 10.10.10.1/24)
I dont’ want this new LAN can be accessed by the actual LAN (192.168.8.1/24)
And also, i want to attach client computer on specific LAN and change it from LAN to another LAN in easy way.
Is it possible with this router?
Below my actual conf
config interface ‘loopback’
option ifname ‘lo’
option proto ‘static’
option ipaddr ‘127.0.0.1’
option netmask ‘255.0.0.0’
config globals ‘globals’
option ula_prefix ‘fded:f2ab:bfbd::/48’
config interface ‘lan’
option type ‘bridge’
option ifname ‘eth1.1’
option netmask ‘255.255.255.0’
option ip6assign ‘60’
option hostname ‘GL-AR750-9c4’
option ipaddr ‘192.168.8.1’
config interface ‘wan’
option ifname ‘eth0’
option proto ‘dhcp’
config interface ‘wan6’
option proto ‘dhcpv6’
option disabled ‘1’
config switch
option name ‘switch0’
option reset ‘1’
option enable_vlan ‘1’
config switch_vlan
option device ‘switch0’
option vlan ‘1’
option ports ‘1 2 0t’
config interface ‘guest’
option ifname ‘guest’
option ipaddr ‘10.10.10.1’
config interface ‘wwan’
option proto ‘dhcp’
option metric ‘20’
Thank you for your help
