DDNS not working properly on Flint 2
Haha I figured that would do it too, and so I do currently have that toggle on, but it doesn’t appear to make the IP address of the ISP router accessible. " xxx.xxx.x.xxx took too long to respond (ERR_CONNECTION_TIMED_OUT).
It’s worth mentioning that it DOES in fact work when WG client is turned off.
Does the ISP router have a private address or a public one?
Because you told before that the ISPs IP is now on the Flint2, so you enabled IP Passthrough?
That is correct, the IP address of the ISP router is now a private one, since the WAN IP is now on the Flint 2. I can access the ISP router if WG client is off, but also want it to work while on.
