I’ve got the DDNS client running under LUCI on a GL-AR300M. It works until the power cycles or reboots but then doesn’t restart after a reboot. When I start the DDNS client again manually everything is fine. Any suggestions on how to automate this? I’m a relative newbie.
Thanks for that suggestion. I tried adding that to the local startup and the DDNS didn’t start on it own after a reboot. Any other suggestions?
Thanks
Problem solved and your suggestion got me going down the right path. Instead of adding ddns restart, I added
/usr/lib/ddns/dynamic_dns_updater.sh -n wan start
and it autostarts after reboot
