DDWRT firmware works on GL-300N and GL-300A. The working one is for buffalo whr 300hp2 and DIR-810L.
Here is a simple guide.
By default it bridges the LAN and WAN. So you need to set up the IP manually if you want to setup DDWRT.
How do you reset the thing after its installed? I can get into uboot, but 30/30/30 doesnt reset it. After its booting i can hold reset till im blue in the face. I ended up uboot and flashing openwrt to reset it.
