Your debricking instructions only mention Windows and MacOS. Does that mean debricking cannot be performed via Linux (Ubuntu)?
The instructions are only on how to set the IP on Windows/MacOS to the correct subnet, which you should be able to find similar instructions for Linux on-line.
Beyond that, all you need is a browser.
Cheers.
Only have Linux and Chromebooks here.
As Eddie says, as long as you know how to set a static IP on your device and have a browser and an ethernet port then all is good.
