Default ssh Password for ar750s
I am trying to remotely ssh into my ar750s it just keeps saying connection refused I dont know the default password for ssh.
It’s the same as your webui admin password with the username being root. If you’re still denied,check your settings at http://192.168.8.1/cgi-bin/luci/admin/system/admin
note: if you changed the router’s lan ip, change it in the url I shared.
Ok I got logged in but it comes back and says no route to host? I am at a loss here think you for your help by the way.
I’m not sure, the only thing I can think of is you’re trying from your normal network and not from the network that the 750s is providing. If that’s the case, you need to connect to the 750s and add a firewall rule to allow traffic on port 22 (ssh) or any other service you want.
Not very sure what happened. Can you post screenshot?
