HI
Im creating image with imagebuilder
for my GL-AR150, but the only remains is how to set root password. I would like to define this directly inside image, is this possible?
Thanks
HI
Thanks
I pushed an update to the Imagebuilder readme, hopefully it’s more clear now how to do it:
You want to basically replace the /etc/shadow and /etc/passwd files following the section " Including / changing files in your image"
