Hello all,
I have 900Mbps connection to xfinity
- (WAN) Results of xfinity.speedtest.com without VPN active is ~700Mbps
- (VPN) Results of speedtest.net with Wireguard active is ~265Mbps
When I activate VPN policies to say “this list bypasses VPN” using MAC addrs:
- (WAN) xfinity test drops to ~425Mbps (-40% !)
- (VPN) speedtest test drops to ~230Mbps (-12%)
Same results if the VPN policies rule is reversed, ie “this list goes through VPN”.
If I turn off VPN and VPN policies, i again get ~700Mbps on WAN
I guess I would expect a small performance hit for processing VPN policies, but losing 40% on the WAN seems excessive. Seems like the performance hit would be more similar for each interface
Thoughts ?
Thanks in advance
Firmware 3.203
