Device bandwidth usage file?
I recall a long time ago, I was able to find the device bandwidth usage file that gl.inet uses to display device stats on the webpage. Anyone know where it might be located? Iā€™d like to use the file for a project :slight_smile:
Do you want client traffic to store files?
Now the new firmware does not have that file.
Ahh does it store the device usage in a db like SQLite?
Yes,it store the device usage in a db.
Ahh ok. Can you pm me the location.
/etc/oui-tertf/client.db
