can you tell me what’s the difference between the SPITZ and the GL.iNet 4G?
I want to use it with my Telekom Sim as a LTE Hotspot with perfect privacy VPN.
Both got the killswitch?
Where can i buy both in Bkk?
Best regards,
Thanks
Best regards,
Thanks
4G router:
Spitz:
Both of them support killswitch.
You can find them in https://store.gl-inet.com/
Thanks for you fast reply.
I want to use it with VPN, just in Germany.
Do you think the spitz will be much better?
I think I will miss the battery, that’s why I ask, otherwise I would take the 4G, but if it’s a big speed difference I take the spitz.
Thank you
