As described in the title I have a problem logging into Captive Portal with expired security certificate.
If I use my old travel router, Google Chrome or Firefox will advise me I can enter the captive Portal if I want, but security is not garanteed. With my GL.Inet GL-AR300M I do not get this option.
Who can help??
If you enabled vpn, you need to disable vpn first.
You also need to uncheck “dns rebinding protection” and disable “dns via TLS” (in firmware v3.x)
Then reconnect your repeater.
