kelcon
October 30, 2015, 11:28pm
I have tried other way - I have used carambola2 and ar150 firmware on my Domino 2.
But both, my ble dongle and usb camera is not recognized (I have installed required kmod-video* modules)
root@GL-AR150:~# lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Both devices works ok on stock CC firmware i.e. on Vocore or Asus routers.
kelcon
October 31, 2015, 12:28am
2
And here is information about gpio.
root@GL-AR150:/etc# cat /sys/kernel/debug/gpio
GPIOs 0-29, ath79:
gpio-0 (gl_ar150:wlan ) out lo
gpio-7 (BTN_7 ) in lo
gpio-8 (BTN_8 ) in lo
gpio-11 (reset ) in lo
gpio-13 (gl_ar150:lan ) out lo
gpio-15 (gl_ar150:wan ) out hi
I suppose that usb is unpowered
kelcon
October 31, 2015, 12:34am
3
Here is Solution:
root@GL-AR150:/# echo 6 > /sys/class/gpio/export
root@GL-AR150:/# echo out > /sys/class/gpio/gpio6/direction
root@GL-AR150:/# echo 1 > /sys/class/gpio/gpio6/value
alzhao
November 2, 2015, 3:04pm
4
Have you tried OpenWrt CC firmware for AR150, downloaded from here: GL.iNet download center
It has the USB power enabled. Actually I am not sure why GPIO 6 is set to low by default in your firmware.
alzhao
November 2, 2015, 4:33pm
5
I see. You want to use Domino firmware on AR150.
Did you user our Domino Patch for OpenWrt CC? Actually in the patch there is code to set GPIO6 to high. If this patch applied, it should works.
You can also directly use our sources, with the patches applied. Here is the file where you can find GPIO6 set to high.
https://github.com/domino-team/openwrt-cc/blob/master/target/linux/ar71xx/files/arch/mips/ath79/mach-domino.c
