Disable Nodogsplash on GL-SFT1200
I've been using the GL-SFT1200 for a month now, and I've noticed that occasionally it displays the Nodogsplash page, preventing internet access until I click 'Continue'.
This is a problem when using a device like a Connected Socket, which relies on constant internet connectivity.
How can I disable Nodogsplash on the GL-SFT1200?
What is the page from? (screenshot if it appears)
GL firmware does not have this page/feature.
Thank you for the reply,
Please find bellow the screenshot:
The GL firmware never pre-install the plugin 'Nodogsplash'.
Did you install this plugin ever?
If not, you can reset the router firmware, or manually remove this plugin in
GL GUI -> Applications -> Plug-ins
Thank you for your assistance.
The issue has been resolved by resetting the router.
