I live in a rural area and have the old ATT iPad plan which is a SIM put into a ZTE velocity hotspot. Internet works fine with that WiFi but I can only connect up to 10 devices. So during Prime Day I bought an AR300M and connect my hotspot to that via usb tethering. At this stage everything works fine still.
I then connect an Ethernet cable to my TP Link AC1750 router you better broadcast the signal through my house and allow me to connect 10+ devices. However, after roughly 24 hours the internet stops working. Everything is still showing as connected and running, but WiFi from my TP link doesn’t work anymore.
I have to constantly unplug and replug cables back in for 20 minutes until it decides to start working again. Is there a reason why this happens? I tried changing the lease time on the velocity hotspot to like a year and thought that would fix the problem. But no luck so far.
No I cannot just disconnect the Ethernet cable. It will definitely not work if the cable is disconnected. I was recommend to try a different power adapter already and that has not worked.
