Just for your information:
The DLNA Server in Beta3 Firmware is not working. You neet to install “libjpeg” as well to make it work.
Regards
Regards
I will check and fix it.
It’s software repo issue, and has been fixed. Please reinstall minidlna ipk, using the following command:
opkg remove luci-app-minidlna
opkg --force-remove remove minidlna
opkg remove libjpeg-turbo
opkg update
opkg install minidlna
On my S1300 device, just the ssh-input
opkg install libjpeg
has fixed the issue. Thank you.
