DMZ and port forwarding at same time?
I have a Flint 2 and a Beryl AX. I noticed that DMZ and port forwarding don’t work at the same time. I saw several posts on the forum asking for this functionality, and staff saying that it would be implemented in firmware 4.2. What are the plans for this to be implemented?
Ok Ijust found a workaround, in luci I just need to put the DMZ rule below all others
Thank you, we’ll find a way to merge it into our firmware.
We haven’t solved the conflict between DMZ and the service on the router itself. But that’s a different issue.
