I've enable DMZ in GL-AXT1800 on one of the systems with reserved dhcp address in the LAN. Now from DMZ host i'm unable to ping or http or ssh to itself using own public ip. however i can connect to it using public ip from other systems on LAN or external network.
It's same issue if i use port forwarding instead of DMZ. I forwarded 22 port to the same machine and can't ssh public ip from it to itself.
I heard its called hairpin NAT, how to fix this on GL-AXT1800
