DNS-Redirect-Manager
Hello and have good day!
After a lot of searching, I couldn’t find any LuCI plugin or built‑in code that allows assigning different DNS servers to specific clients ip. I needed this mainly for my kids’ devices — phones, TVs, and similar. So I created a small script that you can run in your terminal to solve this problem.
You have to set static ip
You can find it here : GitHub - webxperia/DNS-Redirect-Manager: DNS Redirect Manager For GL.inet router
Please want your recommendations.
I have test it in my Flint3 with openwrt 23 and with GL-B3000 (Marble) Success
Interesting. You can however use client tags inside adguard home if you choose to enabled it, that's how I have mine configured.
I enable adguard home and toggle on adguard home to handle clients, that is important so each client gets reported inside adguard home.
Then inside adguard home you can create clients and assign them via Mac address, give each client a different upstream DNS or different blocked apps / blocked app schedules on a per client basis.
