DNS Settings Naming Inconsistency Between App and WebUI
Hello! I believe there is a mistake either on the app or in the webui for the MT3000.
The setting I am talking about is in the DNS section.
On the webui:
  • Allow Custom DNS to Override VPN DNS (If this option is enabled, once you have set custom DNS, packets transmitted through the VPN tunnel will be resolved using the custom DNS override instead of the DNS server settings from the VPN connections.)
This sounds quite clear to me, if enabled, the custom DNS will override the DNS from the VPN.
But then on the app:
  • Allow VPN tunnels to prefer their own DNS
This sounds to me like, if enabled, will do the exact opposite of what it says in the web ui.
One might think these are 2 different settings, but I have verified that these settings toggles correspond to the same setting.
Thanks for your feedback.
I have realized that this description of the APP and Web UI did not correspond.
Will update the APP description.
