I have configured Mullvad VPN on OpenWrt.
Allowed IPs set to 0.0.0.0/0
and checked “route allowed IPs”.
SSH into AX1800, default route is Mullvad VPN.
# route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default * 0.0.0.0 U 0 0 0 MullvadHK04
10.10.20.0 * 255.255.255.0 U 0 0 0 wgserver
89.xxx.xxx.xxx 1-xxx-xxx-223-on 255.255.255.255 UGH 0 0 0 eth0
192.168.0.0 * 255.255.255.0 U 0 0 0 br-guest
192.168.50.0 * 255.255.255.0 U 0 0 0 br-lan
223.xxx.xxx.0 * 255.255.255.0 U 0 0 0 eth0
However, Internet traffic is not going through VPN.
Visiting https://ifconfig.co/ still shows my ISP IP.
AX1800 is on 4.0.1 Beta 2.
By the way, I want to use multiple WireGuard client.
It seems it is not supported on GL-UI, right?
Thanks.
