I see it has an lcd display for it. Is the display used to report for viewing only or can you actually change settings using the lcd display and switch and reset button.
Display only, but it’s so much better than just three little 3 LEDs. See my “mini review”
Has a on/off “programmable” slide switch on the left. Reset button is under the SIM cover and isn’t pin hole but you do need something point to press it with.
