Does not show any SMS text
My x3000 doesn’t display SMS text, what am I doing wrong?
hi,
What is the version of your x3000?The incoming sms are stored in /etc/spool/sms/storage/0001\:01\:00.0/, Could you run cat /etc/spool/sms/storage/0001:01:00.0/* to check whether there have sms body in storage files?
If you tell me exactly how this works, I don’t have much idea! And here is the information about the installed firmware
You have to SSH into your router and execute the command cat /etc/spool/sms/storage/0001:01:00.0/*
Tutorial for windows: SSH to the router - GL.iNet Router Docs 2
For android you could use one of these: Die besten Android-SSH-Clients für das Smartphone (Top-5)
Und jetzt?
You are missing :cat: in front of the directory.
The whole command is
And now?
@fangzekun Your turn :wink:
I found that there is something going wrong with German message parsing.
Thanks a lot ! :grin:
