Very glad that you have got it working the way you wanted it to.
Does this work? I assumed this turned off the radios, so the device couldn’t receive or send. Does the device still receive, but not send?
No. it just disables SSID WiFi broadcast in my case.
Sorry to be dense. Turning off the broadcast of an SSID is an entirely different thing, And I realize I asked two questions, to both of which “no” means that when “enable wifi” is “off”, the device doesn’t receive a signal from an AP.
My AXT1800 receives WiFi signal from parent AP with no issues regardless of whether the “wireless switch” on the GL.iNet is on or off.
Thanks!! Fascinating. My assumption was completely wrong.
TL;DR: ITT no one looked at GL GUI → Network → Network Mode … or reads docs.
“Those who can, do. Those that can’t, teach.”
Guilty as charged. I went back and edited my post to reflect that. Still, it wasn’t clear to me from the documents that setting “enable wifi” to off just affected the broadcast side.
uci show wireless . Have fun.
" [Does Repeater mode repeat on the same SSID?]"
No Answer for this question? Yes or No ???
No.
The SSID will be the one written on the label on the bottom of your router, unless you've changed it.
Why should someone have to listen to, or watch a video, when they've asked a simple question. Just answer the simple question
