Hello Team, is there any api from download center in order to build a script to periodically review if there are a new Firmware , as the Routers with OPt 24, does not check if there are a new Firmware available. Thanks
There is no API available for the Download Center.
You can pull this file once a day https://fw.gl-inet.com/firmware/mt3000-open/testing/list-sha256.txt, and compare whether the version number has changed.
